Disables setting an MPLS packet's EXP value based on the packet's QoS profile.
Disabled.
This command disables setting an MPLS packet's EXP value based on the packet's QoS profile. The QoS profiles to EXP value mappings are configured using the configure mpls exp replacement command.
When disabled, all MPLS packets are transmitted with an EXP value of zero.
The following command disables the setting of an MPLS packet's EXP value based on the packet's QoS profile:
disable mpls exp replacement
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
